# Equipment Schedule
**URL:** <https://forum.inductiveautomation.com/t/equipment-schedule/5394>\
**Created:** [November 9, 2012, 12:00am UTC](https://forum.inductiveautomation.com/t/equipment-schedule/5394 "2012-11-09T00:00:45Z")\
**Posts on this page:** 4\
**Author:** ![Jmoller](https://avatars.discourse-cdn.com/v4/letter/j/0ea827/32.png) [@Jmoller](https://forum.inductiveautomation.com/u/Jmoller)\
**Post date:** [November 9, 2012, 12:00am UTC](https://forum.inductiveautomation.com/t/equipment-schedule/5394/1 "2012-11-09T00:00:45Z")
Is there any way to change the date resolution when spanning it out a month or so? Looks like its possible on the OEE version. Also a .selectedItemID and .selectedDate property.
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [November 14, 2012, 9:59pm UTC](https://forum.inductiveautomation.com/t/equipment-schedule/5394/2 "2012-11-14T21:59:44Z")
You can select a date range for the Equipment Scheduler by using the calendar components. You could also use the Date Range component and bind the Start Date and End Date properties of the scheduler to the Start and End Dates of the Date Range component. Also, you could use 2 Popup Calendars, and bind the scheduler to Date property of those two components, picking one to be the start and the other to be the end date.
**Author:** ![ropsukamp](https://avatars.discourse-cdn.com/v4/letter/r/6a8cbe/32.png) [@ropsukamp](https://forum.inductiveautomation.com/u/ropsukamp)\
**Post date:** [June 27, 2014, 7:37am UTC](https://forum.inductiveautomation.com/t/equipment-schedule/5394/3 "2014-06-27T07:37:44Z")
Moving this into a bit more uncharted territory…
Would it be possible to modify the Equipment Schedule component to not show the days and hours? and ONLY the months? Making it span months is not difficult and binding as you suggest Greg, works fine. But it doesn’t really look very good when the component spans more than a couple of weeks.
I’ve modified/added stuff to other chart components in Ignition using the JFreeChart library. Is it possible to do something similar in this component to only leave the month display on the top part and remove days and hours for example?
**Post date:** [August 14, 2014, 6:04pm UTC](https://forum.inductiveautomation.com/t/equipment-schedule/5394/4 "2014-08-14T18:04:09Z")
Closing this thread since the question was asked in its own.
