# Fail over license installation on local PC
**URL:** <https://forum.inductiveautomation.com/t/fail-over-license-installation-on-local-pc/8987>\
**Category:** General Discussion\
**Created:** [September 2, 2014, 4:57pm UTC](https://forum.inductiveautomation.com/t/fail-over-license-installation-on-local-pc/8987 "2014-09-02T16:57:16Z")\
**Posts on this page:** 3\
**Author:** ![shouldbeonmyboat](https://avatars.discourse-cdn.com/v4/letter/s/e56c9b/32.png) [@shouldbeonmyboat](https://forum.inductiveautomation.com/u/shouldbeonmyboat)\
**Post date:** [September 2, 2014, 4:57pm UTC](https://forum.inductiveautomation.com/t/fail-over-license-installation-on-local-pc/8987/1 "2014-09-02T16:57:16Z")
I just purchased a second license so I can use your fail over function in 7.7 should my network connection fail to my server. Have you created a procedure on how to install this on the local host? I only have a fixed amount of time that I can have this machine down and would like to make it happen with minimal yelling… at me.
Thanks for your help.
**Post date:** [September 2, 2014, 5:11pm UTC](https://forum.inductiveautomation.com/t/fail-over-license-installation-on-local-pc/8987/2 "2014-09-02T17:11:05Z")
There shouldn’t be any downtime involved, you just need to install Ignition on that machine, switch it into local fallback mode, and then make sure there’s a project on there to fallback to. None of this requires that you shutdown the main gateway or the client running on that machine.
See [inductiveautomation.com/support … llback.htm](https://inductiveautomation.com/support/usermanuals/ignition/index.html?local_client_fallback.htm)
**Post date:** [September 4, 2014, 8:22pm UTC](https://forum.inductiveautomation.com/t/fail-over-license-installation-on-local-pc/8987/3 "2014-09-04T20:22:07Z")
Thanks much. I will implement this tomorrow.
