# \[FEATURE\] Add expression function to check if tag is valid (exists and not disabled)
**URL:** <https://forum.inductiveautomation.com/t/feature-add-expression-function-to-check-if-tag-is-valid-exists-and-not-disabled/61192>\
**Created:** [June 25, 2022, 1:07am UTC](https://forum.inductiveautomation.com/t/feature-add-expression-function-to-check-if-tag-is-valid-exists-and-not-disabled/61192 "2022-06-25T01:07:00Z")\
**Showing post:** 6
**Post date:** [August 21, 2023, 3:03am UTC](https://forum.inductiveautomation.com/t/feature-add-expression-function-to-check-if-tag-is-valid-exists-and-not-disabled/61192/6 "2023-08-21T03:03:44Z")
For posterity, this was added into Paul's Ignition Extensions module:
> [@Ignition Extensions - Convenience utilities for advanced users](https://forum.inductiveautomation.com/t/ignition-extensions-convenience-utilities-for-advanced-users/64615):
> Introducing a hopefully community-engaged effort to build a useful repository of scripting and other Ignition utilities for everyone to benefit from. Download the latest release from the [Releases](https://github.com/IgnitionModuleDevelopmentCommunity/ignition-extensions/releases) page and take advantage of the following functions: Scripting Functions system.util system.util.getContext(): Context A convenience function to retrieve the local "context" object, useful as an entrypoint to other advanced scripting. system.util.deepCopy(object): Object Converts a given Pyth…
It would still be nice for this to be added into the product, since this will be unusable in Edge projects ☹
_[View the full topic](https://forum.inductiveautomation.com/t/feature-add-expression-function-to-check-if-tag-is-valid-exists-and-not-disabled/61192)._
