# \[FEATURE\] Needing to restart gateway and designer after changing/adding icon libraries
**URL:** <https://forum.inductiveautomation.com/t/feature-needing-to-restart-gateway-and-designer-after-changing-adding-icon-libraries/112021>\
**Tags:** ignition83\
**Created:** [November 7, 2025, 4:41am UTC](https://forum.inductiveautomation.com/t/feature-needing-to-restart-gateway-and-designer-after-changing-adding-icon-libraries/112021 "2025-11-07T04:41:23Z")\
**Showing post:** 3
**Author:** ![andrew.budaiev](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/andrew.budaiev/32/72921_2.png) [@andrew.budaiev](https://forum.inductiveautomation.com/u/andrew.budaiev)\
**Post date:** [November 7, 2025, 8:15am UTC](https://forum.inductiveautomation.com/t/feature-needing-to-restart-gateway-and-designer-after-changing-adding-icon-libraries/112021/3 "2025-11-07T08:15:50Z")
Check this topic
> [@Custom Icon Library in 8.3](https://forum.inductiveautomation.com/t/custom-icon-library-in-8-3/109259/2):
> Okay, here's the current steps. Navigate to your install directory, and in the /data/config/resources/core/ folder, create a new folder com.inductiveautomation.perspective/ (if it doesn't already exist). Within that folder create an icons/ folder. Within that folder create a \<repository name\>/ folder. Within that folder, create: The spritesheet of your SVG, at whatever arbitrary filename you want, e.g. icons.svg. A config.json file that contains a single entry, svgFileName, that co…
_[View the full topic](https://forum.inductiveautomation.com/t/feature-needing-to-restart-gateway-and-designer-after-changing-adding-icon-libraries/112021)._
