# Filter log severity in system console
**URL:** <https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325>\
**Created:** [April 16, 2014, 5:40pm UTC](https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325 "2014-04-16T17:40:56Z")\
**Posts on this page:** 4\
**Author:** ![iamthebull](https://avatars.discourse-cdn.com/v4/letter/i/58f4c7/32.png) [@iamthebull](https://forum.inductiveautomation.com/u/iamthebull)\
**Post date:** [April 16, 2014, 5:40pm UTC](https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325/1 "2014-04-16T17:40:56Z")
In the system console in the gateway there is a severity drop down. I assumed that if I selected WARN, for example, that it would filter the log and show me only the warnings. It’s not doing that… should it?
Ignition 7.6.6 on Win 7
**Post date:** [April 16, 2014, 5:47pm UTC](https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325/2 "2014-04-16T17:47:25Z")
When you change the level for a logger you aren’t applying a filter to the existing logs, you’re applying a filter to the what level it requires for that particular logger’s messages to make it to the console from that point on.
So changing a logger to WARN should mean that in the future only WARN or higher level messages from that logger make it to the console.
**Post date:** [April 16, 2014, 5:50pm UTC](https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325/3 "2014-04-16T17:50:16Z")
Ok. Clear.
Is there a way to filter the log at all? If not, could you consider this a feature request to do so?
**Post date:** [April 16, 2014, 5:57pm UTC](https://forum.inductiveautomation.com/t/filter-log-severity-in-system-console/8325/4 "2014-04-16T17:57:42Z")
[quote=“iamthebull”]Ok. Clear.
Is there a way to filter the log at all? If not, could you consider this a feature request to do so?[/quote]
Making that log console suck considerably less is something we’re hoping to get done for 7.7.
