Hello everyone,
I was going through the user manual and other topics in the forum about the use of filterTag extension function under Tag Browse Tree.
But unfortunately, i didn’t find any helpful information relating to it.
It would be delightful to know how to use the filterTag extension function to make particular tag invisible in tag browse tree during runtime if all tag present in same tag provider.
The tag object you get passed to you contains some information you may find useful to accomplish your task. Put this in your script to find out the methods and attributes available.
print dir(tag)
return true
You can definitely filter out any tag you want, but I’m not sure what you mean by “if all tag present in same tag provider”.
Hi @pturmel,
I went through all the discussions relating to filterTag, I saw one of your suggestions too in Limit the information displayed when using the Tag Browse Tree.
You have suggested the implementation of the filterTag extension function.
But working example code for implementing it would be appreciated.
I have tried the code explained in other discussions relating to FilterTag function, But didn’t seem to workout.
But why not use the realtime tag mode and just check the box that says “Include Historical Tags” and uncheck the box that says “Include Realtime Tags”. This will provide to you only the historical tags with no scripting.
Hi @brandon1,
I am already using the historical tag mode, my query is how to make invisible some historical tags from historical tag browse tree as per the choice.
I have only tried this code in the realtime tag mode. I’m not sure how it would work in the historical mode.
Try just printing out tag.name and always returning true to make sure tag.name returns what you think it should.
