# Gateway / Java question 7.7.2
**URL:** <https://forum.inductiveautomation.com/t/gateway-java-question-7-7-2/10402>\
**Created:** [August 26, 2015, 8:22pm UTC](https://forum.inductiveautomation.com/t/gateway-java-question-7-7-2/10402 "2015-08-26T20:22:46Z")\
**Showing post:** 11
**Author:** ![Miguel\_Cimildoro](https://avatars.discourse-cdn.com/v4/letter/m/53a042/32.png) [@Miguel\_Cimildoro](https://forum.inductiveautomation.com/u/Miguel_Cimildoro)\
**Post date:** [November 14, 2023, 12:19pm UTC](https://forum.inductiveautomation.com/t/gateway-java-question-7-7-2/10402/11 "2023-11-14T12:19:21Z")
Hi Phil,
I created a post similar to this one, as I think I have the same problem. Please could you take a look at it and confirm if my problem is related to this, is that configuration the recommended one to avoid high CPU performance?
> [@CPU and RAM problems: Clock events and Garbage Collector configuration](https://forum.inductiveautomation.com/t/cpu-and-ram-problems-clock-events-and-garbage-collector-configuration/81850):
> Hello Ignition community, I am experiencing problems related to high CPU and RAM usage on my SCADA system. I have observed SCADA clock events that seem to be linked to memory release by the Garbage Collector. Despite having the Garbage Collector configured in the ignition.conf file, I am still facing these issues. Attached you will find two images illustrating the problems: the first one shows the system performance indicators, highlighting a CPU usage of 77% and a memory usage exceeding 50,00…
_[View the full topic](https://forum.inductiveautomation.com/t/gateway-java-question-7-7-2/10402)._
