# Gateway Restore command (gwcmd) showing warning and needs manual startup
**URL:** <https://forum.inductiveautomation.com/t/gateway-restore-command-gwcmd-showing-warning-and-needs-manual-startup/74937>\
**Tags:** ignition81\
**Created:** [June 13, 2023, 2:08am UTC](https://forum.inductiveautomation.com/t/gateway-restore-command-gwcmd-showing-warning-and-needs-manual-startup/74937 "2023-06-13T02:08:30Z")\
**Showing post:** 7
**Author:** ![kcollins](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kcollins/32/19646_2.png) [@kcollins](https://forum.inductiveautomation.com/u/kcollins)\
**Post date:** [June 13, 2023, 1:40pm UTC](https://forum.inductiveautomation.com/t/gateway-restore-command-gwcmd-showing-warning-and-needs-manual-startup/74937/7 "2023-06-13T13:40:26Z")
Agreed on the systemd override configuration so that it will persist across Ignition upgrades (that might set/reset the base service configuration). Take a look at [this post](https://forum.inductiveautomation.com/t/ignition-8-1-commissioning-automation/61034/7) for some demo's you might find useful.
_[View the full topic](https://forum.inductiveautomation.com/t/gateway-restore-command-gwcmd-showing-warning-and-needs-manual-startup/74937)._
