# Gateway Script httpGet CONNECTION RESET ERROR
**URL:** <https://forum.inductiveautomation.com/t/gateway-script-httpget-connection-reset-error/19365>\
**Created:** [August 22, 2018, 7:12pm UTC](https://forum.inductiveautomation.com/t/gateway-script-httpget-connection-reset-error/19365 "2018-08-22T19:12:05Z")\
**Showing post:** 13
**Author:** ![christopher.panici](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/christopher.panici/32/5814_2.png) [@christopher.panici](https://forum.inductiveautomation.com/u/christopher.panici)\
**Post date:** [August 22, 2018, 7:53pm UTC](https://forum.inductiveautomation.com/t/gateway-script-httpget-connection-reset-error/19365/13 "2018-08-22T19:53:29Z")
I found this interesting:
> [@Gateway Timer Script and httpGet Problem](http://forum.inductiveautomation.com/t/gateway-timer-script-and-httpget-problem/5229):
> I received the following error (IOError: Connection timed out: connect) when trying to execute the httpGet command from within the Gateway Event Scripts. As noted in other threads the scripts works fine from a button. I understand that the client side execution is different from the server side execution. Therefore, I ran a client instance (button test) on the gateway server machine and it works as well as verifying the URL is visible through Internet Explorer and disabled firewalls, so I do …
_[View the full topic](https://forum.inductiveautomation.com/t/gateway-script-httpget-connection-reset-error/19365)._
