# Global Layout Issue: Sidebar Always Appears and Can't Adapt to 1920x1080 Resolution
**URL:** <https://forum.inductiveautomation.com/t/global-layout-issue-sidebar-always-appears-and-cant-adapt-to-1920x1080-resolution/71481>\
**Tags:** ignition81\
**Created:** [March 23, 2023, 9:49am UTC](https://forum.inductiveautomation.com/t/global-layout-issue-sidebar-always-appears-and-cant-adapt-to-1920x1080-resolution/71481 "2023-03-23T09:49:32Z")\
**Showing post:** 5
**Post date:** [March 23, 2023, 6:56pm UTC](https://forum.inductiveautomation.com/t/global-layout-issue-sidebar-always-appears-and-cant-adapt-to-1920x1080-resolution/71481/5 "2023-03-23T18:56:05Z")
> [@Auto Resize windows to fit various vision client screen size without scroll bars](https://forum.inductiveautomation.com/t/auto-resize-windows-to-fit-various-vision-client-screen-size-without-scroll-bars/28333/2):
> You can try adjusting the minimum size in the project settings (Client // User Interface). It should allow the windows to shrink down to it. There is also a minimum size setting for each window, but it defaults to 0 x 0. May still be good to look for a sanity check. From a personal design standpoint, I set minimum size to 10 x 10 pixels smaller than the lowest resolution I want to support. Then I design the windows to fit that minimum size.
_[View the full topic](https://forum.inductiveautomation.com/t/global-layout-issue-sidebar-always-appears-and-cant-adapt-to-1920x1080-resolution/71481)._
