# Gradient orientation
**URL:** <https://forum.inductiveautomation.com/t/gradient-orientation/8613>\
**Created:** [June 24, 2014, 10:46pm UTC](https://forum.inductiveautomation.com/t/gradient-orientation/8613 "2014-06-24T22:46:45Z")\
**Posts on this page:** 1\
**Author:** ![JGJohnson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jgjohnson/32/29582_2.png) [@JGJohnson](https://forum.inductiveautomation.com/u/JGJohnson)\
**Post date:** [June 24, 2014, 10:46pm UTC](https://forum.inductiveautomation.com/t/gradient-orientation/8613/1 "2014-06-24T22:46:45Z")
It’s very easy to get just a tiny bit off when orienting a gradient and when the item is resized smaller the gradient skews in a nasty way. Also, I almost always do vertical gradients so pretty much every time I add a gradient I have to orient it.
It would be really helpful to have any of the following options available when using the gradient orientation tool:
-Have the orientation vertical instead of horizontal as the default.
-Be able to enter the orientation in degrees. 45, 90, 180º etc.
-Be able to hold down control and snap to angles like on the line tool.
-Show coordinates for the endpoints as a user is moving them.
-Highlight the endpoints when they have either the same x or y value
The item in bold would probably be my preferred solution.
If any of these features have already been implemented in newer version then never mind.
