# Hard coded request for HTTP in Designer Launcher even if gateway set up for HTTPS
**URL:** <https://forum.inductiveautomation.com/t/hard-coded-request-for-http-in-designer-launcher-even-if-gateway-set-up-for-https/34027>\
**Created:** [April 18, 2020, 12:05pm UTC](https://forum.inductiveautomation.com/t/hard-coded-request-for-http-in-designer-launcher-even-if-gateway-set-up-for-https/34027 "2020-04-18T12:05:27Z")\
**Showing post:** 11
**Author:** ![kcollins](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kcollins/32/19646_2.png) [@kcollins](https://forum.inductiveautomation.com/u/kcollins)\
**Post date:** [May 26, 2021, 2:31pm UTC](https://forum.inductiveautomation.com/t/hard-coded-request-for-http-in-designer-launcher-even-if-gateway-set-up-for-https/34027/11 "2021-05-26T14:31:52Z")
Designer Launcher in 8.1.6 now uses `/StatusPing` directly, so you will no longer need the explicit rewrite. Thankfully, you can also use the new launcher for older gateways that you’ve not yet upgraded since the issue was resolved in the launcher itself.
_[View the full topic](https://forum.inductiveautomation.com/t/hard-coded-request-for-http-in-designer-launcher-even-if-gateway-set-up-for-https/34027)._
