# Help inserting rows of totals to a dataset from a query
**URL:** <https://forum.inductiveautomation.com/t/help-inserting-rows-of-totals-to-a-dataset-from-a-query/64498>\
**Created:** [September 26, 2022, 7:46pm UTC](https://forum.inductiveautomation.com/t/help-inserting-rows-of-totals-to-a-dataset-from-a-query/64498 "2022-09-26T19:46:38Z")\
**Showing post:** 12
**Post date:** [September 27, 2022, 1:43am UTC](https://forum.inductiveautomation.com/t/help-inserting-rows-of-totals-to-a-dataset-from-a-query/64498/12 "2022-09-27T01:43:43Z")
Assuming your query will return something with `ORDER BY Timestamp, Shift, Line` to give data as in your original post. I would even go so far as to use just the date portion of `Timestamp`. Then, you are just looking for changes in either the date or the shift.
```python
sampleHeaders = ['Line', 'Shift', 'Hours', 'Gross', 'Net', 'Timestamp']
sampleData = [['K01', 1, 12, 200, 150, system.date.parse('2022-09-25', 'yyyy-MM-DD')],
              ['K02', 1, 12, 202, 152, system.date.parse('2022-09-25', 'yyyy-MM-DD')],
              ['K03', 1, 12, 203, 153, system.date.parse('2022-09-25', 'yyyy-MM-DD')],
              ['K01', 2, 12, 200, 150, system.date.parse('2022-09-25', 'yyyy-MM-DD')],
              ['K02', 2, 12, 208, 155, system.date.parse('2022-09-25', 'yyyy-MM-DD')],
              ['K03', 2, 12, 209, 157, system.date.parse('2022-09-25', 'yyyy-MM-DD')]
datasetIn = system.dataset.toPyDataSet(system.dataset.toDataSet(sampleHeaders, sampleData))
#util.printDataSet(datasetIn)
#print ''
headers = list(datasetIn.getColumnNames())
dataOut = []
grossSum = netSum = 0
for row, nextRow in zip(datasetIn, datasetIn[1:]):
	# Add values for the row
	grossSum += row['Gross']
	netSum += row['Net']
	# Append the row into the output data
	dataOut.append(list(row))
	# Compare the timestamp and shift values to the next row.
	# If they're different, append the total row to the output data.
	if row['Timestamp'] != nextRow['Timestamp'] or row['Shift'] != nextRow['Shift']:
		dataOut.append(['Total', None, None, grossSum, netSum, None])
		grossSum=0
		netSum = 0
# Process the final row
grossSum += nextRow['Gross']
netSum += nextRow['Net']
dataOut.append(list(nextRow))
# Create the dataset
datasetOut = system.dataset.toDataSet(headers, dataOut)
#util.printDataSet(datasetOut)
Output:
```nohighlight
row | Line | Shift | Hours | Gross | Net | Timestamp
0 | K01 | 1 | 12 | 200 | 150 | Tue Jan 25 00:00:00 EST 2022
1 | K02 | 1 | 12 | 202 | 152 | Tue Jan 25 00:00:00 EST 2022
2 | K03 | 1 | 12 | 203 | 153 | Tue Jan 25 00:00:00 EST 2022
3 | K01 | 2 | 12 | 200 | 150 | Tue Jan 25 00:00:00 EST 2022
4 | K02 | 2 | 12 | 208 | 155 | Tue Jan 25 00:00:00 EST 2022
5 | K03 | 2 | 12 | 209 | 157 | Tue Jan 25 00:00:00 EST 2022
3 | Total | None | None | 605 | 455 | None
4 | K01 | 2 | 12 | 200 | 150 | Tue Jan 25 00:00:00 EST 2022
5 | K02 | 2 | 12 | 208 | 155 | Tue Jan 25 00:00:00 EST 2022
6 | K03 | 2 | 12 | 209 | 157 | Tue Jan 25 00:00:00 EST 2022
7 | Total | None | None | 617 | 462 | None
_[View the full topic](https://forum.inductiveautomation.com/t/help-inserting-rows-of-totals-to-a-dataset-from-a-query/64498)._
