# Help! Launch tag by time
**URL:** <https://forum.inductiveautomation.com/t/help-launch-tag-by-time/24481>\
**Created:** [April 29, 2019, 8:21pm UTC](https://forum.inductiveautomation.com/t/help-launch-tag-by-time/24481 "2019-04-29T20:21:23Z")\
**Showing post:** 3
**Post date:** [April 30, 2019, 12:44pm UTC](https://forum.inductiveautomation.com/t/help-launch-tag-by-time/24481/3 "2019-04-30T12:44:46Z")
Dude! Don't post multiple topics for the same problem! I just found your other post:
> [@Inverter power control](http://forum.inductiveautomation.com/t/inverter-power-control/24494):
> I have a problem. I im using ignition 7.5.12 Connecting connecting inverters via modbus tcp. There is a solar power plant where 80 inverters are installed. Each inverter has a power regulation function by a tag. It is necessary to set the value for example: the power plant should work tomorrow at 11:00 with the total power of 2000 kW, 12:00 2100 kW and so on … How can this be implemented? Requires 2000KV / 80 = 25KW (this value should be automatically recorded to each inverter )
_[View the full topic](https://forum.inductiveautomation.com/t/help-launch-tag-by-time/24481)._
