# How to change the property of a component from the frontend code
**URL:** <https://forum.inductiveautomation.com/t/how-to-change-the-property-of-a-component-from-the-frontend-code/90469>\
**Tags:** perspective\
**Created:** [May 16, 2024, 2:16am UTC](https://forum.inductiveautomation.com/t/how-to-change-the-property-of-a-component-from-the-frontend-code/90469 "2024-05-16T02:16:42Z")\
**Post date:** [May 16, 2024, 6:21am UTC](https://forum.inductiveautomation.com/t/how-to-change-the-property-of-a-component-from-the-frontend-code/90469/2 "2024-05-16T06:21:20Z")
> [@How to update custom component props in the designer](https://forum.inductiveautomation.com/t/how-to-update-custom-component-props-in-the-designer/85391/3):
> If you really need to write it manually, then you should have access to an implicit props that contains a reference to the ComponentStore, which itself contains a reference to the component's props, meta, custom as PropertyTree objects with a write method, e.g: this.props.store.props.write("path", value); However, the input fields in Perspective are a fair bit more complicated than just simple \<Input\> wrappers since they need to handle theming across browsers, the "defer updates" settings, and…
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-change-the-property-of-a-component-from-the-frontend-code/90469)._
