# How to Close a Perspective Popup Asynchronously After a Delay in Ignition?
**URL:** <https://forum.inductiveautomation.com/t/how-to-close-a-perspective-popup-asynchronously-after-a-delay-in-ignition/99869>\
**Tags:** perspective, ignition81\
**Created:** [December 16, 2024, 11:06am UTC](https://forum.inductiveautomation.com/t/how-to-close-a-perspective-popup-asynchronously-after-a-delay-in-ignition/99869 "2024-12-16T11:06:33Z")\
**Showing post:** 4
**Post date:** [January 5, 2025, 5:07pm UTC](https://forum.inductiveautomation.com/t/how-to-close-a-perspective-popup-asynchronously-after-a-delay-in-ignition/99869/4 "2025-01-05T17:07:54Z")
- In Project Browser, select the root of your view.
- In Perspective Property Editor scroll down to CUSTOM.
- Create a new custom property `startTime`.
  - Create an expression binding on `startTime` with the expression, `now(0)`. This will fire once when the popup opens and save the current timestamp in the custom property.
- Create a second tag, `timeout`.
  - Add an expression binding,
`(now(1000) - {this.custom.startTime}) > 5000`
This will evaluate every 1000 ms and will return `true` when the popup has been open for 5000 ms.
- Right-click on `custom.timeout` and select Edit Change Script. Add the script,
```python
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
	if currentValue.value:
		system.perspective.closePopup("")
Tips:
`now(0)` → Runs once on load.
`now()` → Runs at the default scan rate - typically 1000 ms.
`now(4321)` → Runs every 4321 ms.
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-close-a-perspective-popup-asynchronously-after-a-delay-in-ignition/99869)._
