# How to map OPC UDT to Ignition template
**URL:** <https://forum.inductiveautomation.com/t/how-to-map-opc-udt-to-ignition-template/27269>\
**Created:** [August 8, 2019, 2:52pm UTC](https://forum.inductiveautomation.com/t/how-to-map-opc-udt-to-ignition-template/27269 "2019-08-08T14:52:42Z")\
**Post date:** [August 8, 2019, 3:12pm UTC](https://forum.inductiveautomation.com/t/how-to-map-opc-udt-to-ignition-template/27269/2 "2019-08-08T15:12:18Z")
It might be easier if you turn these into Ignition UDTs using the strategy outlined in this post: [OPC UA struct data type?](http://forum.inductiveautomation.com/t/opc-ua-struct-data-type/26905/2?u=kevin.herron)
You might also be able to skip that and use `jsonGet` and `jsonSet` from your template bindings. But it wouldn’t happen automatically.
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-map-opc-udt-to-ignition-template/27269)._
