# How to set default foreground color back to 0,0,0
**URL:** <https://forum.inductiveautomation.com/t/how-to-set-default-foreground-color-back-to-0-0-0/52420>\
**Created:** [October 27, 2021, 8:25pm UTC](https://forum.inductiveautomation.com/t/how-to-set-default-foreground-color-back-to-0-0-0/52420 "2021-10-27T20:25:21Z")\
**Showing post:** 8
**Post date:** [October 28, 2021, 7:13pm UTC](https://forum.inductiveautomation.com/t/how-to-set-default-foreground-color-back-to-0-0-0/52420/8 "2021-10-28T19:13:14Z")
While we're on the topic of default colour changes, you will find that all your default colour buttons have changed from almost white to blue, and page backgrounds have changed from a nice, minimal eye-strain EEECE8, to a bright, eye-straining, almost white :/. I actually don't mind the black change as I try not to use full black anywhere anyway. The new page colour though is horrendous and I go through and change this EVERYwhere. It affects containers as well. Very annoying...
Also, might be useful:
> [@Undocumented changes when migrating from v7 to v8](https://forum.inductiveautomation.com/t/undocumented-changes-when-migrating-from-v7-to-v8/38044):
> Just some items I’ve found during v7 to v8 upgrades that may not be documented (some of them might be) and can cause hiccups (and quite a bit of work, relatively speaking!). The official guide to upgrading from IA is [here](https://docs.inductiveautomation.com/display/DOC81/Ignition+8+Upgrade+Guide). Tags: UDT v7 property UDTParentType has been renamed in v8 to TypeId Tag quality string values have changed. E.g. EDITED FOR 8.1.10 below 8.1.10 “Not Found” ==\> “Bad\_NotFound”; “Disabled” ==\> “Bad\_Disabled”; 8.1.10 and above “Bad\_NotFound(Error description…)”, “Bad\_ErrorC…
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-set-default-foreground-color-back-to-0-0-0/52420)._
