# How to use Multi-Select Dropdown and filter the Power Table
**URL:** <https://forum.inductiveautomation.com/t/how-to-use-multi-select-dropdown-and-filter-the-power-table/84260>\
**Tags:** vision\
**Created:** [January 15, 2024, 4:56am UTC](https://forum.inductiveautomation.com/t/how-to-use-multi-select-dropdown-and-filter-the-power-table/84260 "2024-01-15T04:56:27Z")\
**Showing post:** 6
**Post date:** [January 16, 2024, 2:27am UTC](https://forum.inductiveautomation.com/t/how-to-use-multi-select-dropdown-and-filter-the-power-table/84260/6 "2024-01-16T02:27:03Z")
I'm off tomorrow, so if you haven't figured this out by then, I'll set something up in my test environment to demonstrate a few ways to do this.
> [@Matthew\_Lam](#):
> {Root Container.Container.MultiSelectDropdown.selectedLabels}
I imagine that you will need to get the column as a list to make it useful for querying, which means you would have to script the query on the `selectedLabels` propertyChange event.
The script would look something like this:
```auto
Written for the script editor of the multiselect dropdown's propertyChange event handler
# If and only if the selectedLabels property of the multiselect dropdown changes
if event.propertyName == 'selectedLabels':
	# Get the labels as a list
	labels = event.source.selectedLabels.getColumnAsList(0)
	# Create a parameterized query query and match the number of parameters to the number of labels
	query = "SELECT * FROM KoroitSamples WHERE KoroitSamples.[Instrument] IN (%s)" % ', '.join('?' for item in labels)
	database = #The database name will need to be defined
	# Run the query and assign its result to the data property of the power table
	# Change this path to the relative path of the power table
	event.source.parent.getComponent('Power Table').data = system.db.runPrepQuery(query, labels, database)
That script looks proper by my eyes, but full disclosure: I'm not where I can test code at the moment.
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-use-multi-select-dropdown-and-filter-the-power-table/84260)._
