# How to use the source filter of Alarm Status Table in the popup window
**URL:** <https://forum.inductiveautomation.com/t/how-to-use-the-source-filter-of-alarm-status-table-in-the-popup-window/64463>\
**Tags:** ignition81\
**Created:** [September 26, 2022, 5:29am UTC](https://forum.inductiveautomation.com/t/how-to-use-the-source-filter-of-alarm-status-table-in-the-popup-window/64463 "2022-09-26T05:29:45Z")\
**Post date:** [September 26, 2022, 10:39am UTC](https://forum.inductiveautomation.com/t/how-to-use-the-source-filter-of-alarm-status-table-in-the-popup-window/64463/2 "2022-09-26T10:39:36Z")
Youll need to put wildcards (\*) around your tag path filter, and, depending on version you’re running, you might also need some other stuff at the start as well. See this post [system.alarm.queryStatus broken in 7.9.5? - #3 by nminchin](https://forum.inductiveautomation.com/t/system-alarm-querystatus-broken-in-7-9-5/16279/3)
_[View the full topic](https://forum.inductiveautomation.com/t/how-to-use-the-source-filter-of-alarm-status-table-in-the-popup-window/64463)._
