# HTTP Client Connect Timeout when curl command on same device works with the same endpoint
**URL:** <https://forum.inductiveautomation.com/t/http-client-connect-timeout-when-curl-command-on-same-device-works-with-the-same-endpoint/94244>\
**Tags:** ignition81\
**Created:** [August 6, 2024, 6:42pm UTC](https://forum.inductiveautomation.com/t/http-client-connect-timeout-when-curl-command-on-same-device-works-with-the-same-endpoint/94244 "2024-08-06T18:42:04Z")\
**Showing post:** 10
**Post date:** [August 6, 2024, 7:01pm UTC](https://forum.inductiveautomation.com/t/http-client-connect-timeout-when-curl-command-on-same-device-works-with-the-same-endpoint/94244/10 "2024-08-06T19:01:47Z")
Pssst!
You may find my [@system.util.runInGateway](https://www.automation-pros.com/toolkit/doc/utility.html#runingateway) decorator helpful.
See also:
> [@Automation Professionals' Integration Toolkit Module](https://forum.inductiveautomation.com/t/automation-professionals-integration-toolkit-module/74934/122):
> Automation Professionals is pleased to announce a beta release of this Integration Toolkit: For Ignition v8.1+, as usual: v2.0.16.241352008 This beta introduces a number of new scripting features: Inspired by @Mathias_Melling above, the souped-up dictionary functionality of the BindableVarMap data type has been factored out, as [system.util.VarMap](https://www.automation-pros.com/toolkit/doc/scripting.html#varmap). Serializable to the extent its contents are serializable, just like dictionaries, and safe for use with persistence. grin The PythonAsJavaE…
_[View the full topic](https://forum.inductiveautomation.com/t/http-client-connect-timeout-when-curl-command-on-same-device-works-with-the-same-endpoint/94244)._
