# HTTP Request "No route to host", but only problem is with Ignition
**URL:** <https://forum.inductiveautomation.com/t/http-request-no-route-to-host-but-only-problem-is-with-ignition/107743>\
**Created:** [June 25, 2025, 12:23am UTC](https://forum.inductiveautomation.com/t/http-request-no-route-to-host-but-only-problem-is-with-ignition/107743 "2025-06-25T00:23:49Z")\
**Showing post:** 14
**Author:** ![Tburgess](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/tburgess/32/67018_2.png) [@Tburgess](https://forum.inductiveautomation.com/u/Tburgess)\
**Post date:** [June 25, 2025, 2:35am UTC](https://forum.inductiveautomation.com/t/http-request-no-route-to-host-but-only-problem-is-with-ignition/107743/14 "2025-06-25T02:35:30Z")
Updates:
**Docker Image:** HTTP binding has no issue now and the no route to error has disappeared, however, I am unable to save the project or see session props unless I do the fix laid out here:
> [@\[IGN-12611\] Basic session properties gone 8.1.47](https://forum.inductiveautomation.com/t/ign-12611-basic-session-properties-gone-8-1-47/105231/4):
> This is the only standout information I get from the output console on startup but its all level INFO 12:02:24.891 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+10534] 12:02:26.871 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module. Mode: Activated 12:02:29.222 [Browser Thread: 6b4a9901-588e-492e-9fa8-529d2e71c788] INFO Perspective.SessionProps -- [mobx] Encountered an uncaught exception that was thrown by a reaction or observer component, …
But currently workable
**Zip installer:** Uninstalled and reinstalled ignition with the zip installers through my terminals. while it has the same issue as above (I have to click File \> Open in my already opened project to save and see session props ), the issue with the HTTP binding is resolved!
So my takeaway is in the future if I install Ignition on macOS to use the zip installer instead of the .dmg
_[View the full topic](https://forum.inductiveautomation.com/t/http-request-no-route-to-host-but-only-problem-is-with-ignition/107743)._
