# Ignition 7.9.10 client launcher with Ignition 8.0.1 Gateway
**URL:** <https://forum.inductiveautomation.com/t/ignition-7-9-10-client-launcher-with-ignition-8-0-1-gateway/25212>\
**Created:** [May 22, 2019, 2:49am UTC](https://forum.inductiveautomation.com/t/ignition-7-9-10-client-launcher-with-ignition-8-0-1-gateway/25212 "2019-05-22T02:49:24Z")\
**Post date:** [May 22, 2019, 2:53am UTC](https://forum.inductiveautomation.com/t/ignition-7-9-10-client-launcher-with-ignition-8-0-1-gateway/25212/2 "2019-05-22T02:53:58Z")
No, they won’t work.
[This post](http://forum.inductiveautomation.com/t/version-8-32-bit-vision-clients/24658/4?u=kevin.herron) has some shell scripts you can use to launch a client on a 32-bit system using a JRE that’s already installed. They require the JAVA\_HOME environment variable to be set.
We’re shipping slightly more polished versions of these shell scripts with 8.0.2 or 8.0.3, but that’s the extent of support/workaround we’re going to have for 32-bit systems.
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-7-9-10-client-launcher-with-ignition-8-0-1-gateway/25212)._
