# Ignition 8.1.28 61850 able to grab values from Model but not Reports
**URL:** <https://forum.inductiveautomation.com/t/ignition-8-1-28-61850-able-to-grab-values-from-model-but-not-reports/78832>\
**Tags:** ignition81\
**Created:** [September 6, 2023, 8:00pm UTC](https://forum.inductiveautomation.com/t/ignition-8-1-28-61850-able-to-grab-values-from-model-but-not-reports/78832 "2023-09-06T20:00:29Z")\
**Showing post:** 3
**Author:** ![Pofer\_Wang](https://avatars.discourse-cdn.com/v4/letter/p/f4b2a3/32.png) [@Pofer\_Wang](https://forum.inductiveautomation.com/u/Pofer_Wang)\
**Post date:** [June 13, 2024, 5:44pm UTC](https://forum.inductiveautomation.com/t/ignition-8-1-28-61850-able-to-grab-values-from-model-but-not-reports/78832/3 "2024-06-13T17:44:20Z")
I have encountered the same issue.
I found that when I chose to use REPORT1, even though I confirmed my packets using Wireshark, no data appeared. However, when I chose REPORT6, the data could be received normally.
I have also raised some questions about 61850. You can refer to this post:
> [@61850 Driver MMS Report issues](https://forum.inductiveautomation.com/t/61850-driver-mms-report-issues/91809):
> Hello, I have a few questions about the 61850 REPORT function. As shown in the picture, I selected REPORT 1 and confirmed that RptEna is checked, but I cannot receive the data. If I select REPORT 6, my RptEna is not checked, but I can still receive the data. I see the correct timestamp on the CB stVal, but in the settings, I did not check Report Timestamp. On the contrary, when I check it, the timestamp becomes incorrect. I have alrea…
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-8-1-28-61850-able-to-grab-values-from-model-but-not-reports/78832)._
