# Ignition 8.1 Commissioning Automation
**URL:** <https://forum.inductiveautomation.com/t/ignition-8-1-commissioning-automation/61034>\
**Tags:** ignition81\
**Created:** [June 21, 2022, 9:08pm UTC](https://forum.inductiveautomation.com/t/ignition-8-1-commissioning-automation/61034 "2022-06-21T21:08:02Z")\
**Showing post:** 7
**Author:** ![kcollins](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kcollins/32/19646_2.png) [@kcollins](https://forum.inductiveautomation.com/u/kcollins)\
**Post date:** [June 22, 2022, 8:56pm UTC](https://forum.inductiveautomation.com/t/ignition-8-1-commissioning-automation/61034/7 "2022-06-22T20:56:12Z")
> [@ralacosta](#):
> I was looking to see if there was a way to skip the EULA in the same way. The provided Github repo solution uses curl and basically accepts the EULA that way.
Ahhh, I see.. Yes, it would be easiest to just add the `ACCEPT_IGNITION_EULA=Y` var to your environment then.. If you're on Linux, see an example below for updating the systemd override file with additional environment variables:
[https://asciinema.org/a/KnHcZHFOxr5cPNkOR4BkEPnNO](https://asciinema.org/a/KnHcZHFOxr5cPNkOR4BkEPnNO)
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-8-1-commissioning-automation/61034)._
