# Ignition 8.3 - Installing Designer Launcher - Ubuntu 22.04
**URL:** <https://forum.inductiveautomation.com/t/ignition-8-3-installing-designer-launcher-ubuntu-22-04/111701>\
**Tags:** ignition83, designer\
**Created:** [October 24, 2025, 1:32pm UTC](https://forum.inductiveautomation.com/t/ignition-8-3-installing-designer-launcher-ubuntu-22-04/111701 "2025-10-24T13:32:58Z")\
**Author:** ![Spencer\_Lommel1](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/spencer_lommel1/32/78679_2.png) [@Spencer\_Lommel1](https://forum.inductiveautomation.com/u/Spencer_Lommel1)\
**Post date:** [October 24, 2025, 1:50pm UTC](https://forum.inductiveautomation.com/t/ignition-8-3-installing-designer-launcher-ubuntu-22-04/111701/2 "2025-10-24T13:50:31Z")
This is pretty similar to this post which contains a good answer
> [@Best practices for 8.1 Designer Launcher install on Linux?](https://forum.inductiveautomation.com/t/best-practices-for-8-1-designer-launcher-install-on-linux/40302/4):
> I'm going to answer my own question here. The designerlauncher.desktop file is a file that specifies where an application exists and how a Linux desktop such as Gnome (or other [freedesktop.org](http://freedesktop.org) compliant applications) can start it from an icon. These desktop systems assign icons to applications by registering each application's ".desktop" file. There are 2 main locations where the ".desktop" file should be placed in order for this to occur: /usr/share/applications =\> For globally accessibl…
Essentially you install it like any other software on Linux when not installing with a package manager. You just put it in whatever directory you install applications which is usually something like
`~/opt` on Ubuntu for user level apps or `/opt` for system wide.
This also wont make a `.desktop` launcher on it’s own but this does a decent job explaining how to do that:
> <https://superuser.com/questions/1782591/where-should-i-place-desktop-files-for-3rd-party-apps-installed-in-opt>
Now you should have enough info to Google any remaining questions from here since the install process for the designerlauncher is pretty standard compared to other Linux applications
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-8-3-installing-designer-launcher-ubuntu-22-04/111701)._
