# Ignition 8 - Memory leak
**URL:** <https://forum.inductiveautomation.com/t/ignition-8-memory-leak/45851>\
**Tags:** ignition80\
**Created:** [April 21, 2021, 8:46am UTC](https://forum.inductiveautomation.com/t/ignition-8-memory-leak/45851 "2021-04-21T08:46:41Z")\
**Post date:** [April 21, 2021, 9:39am UTC](https://forum.inductiveautomation.com/t/ignition-8-memory-leak/45851/2 "2021-04-21T09:39:25Z")
> [@Ignition server memory increasing](http://forum.inductiveautomation.com/t/ignition-server-memory-increasing/43932/4):
> Firing off async threads without a means to kill off. A single jython async thread stuck in an infinite wait or infinite loop will hold the entire old interpreter in memory after a scripting restart. Opening python sockets without try-finally guards to close. Attaching python listeners to java infrastructure with no way to remove/retire. Caching python objects without control over lifetimes. All of the above are prone to happen regularly as projects are edited and scripts are restarted (pe…
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-8-memory-leak/45851)._
