# Ignition and Studio 5000 Emulator
**URL:** <https://forum.inductiveautomation.com/t/ignition-and-studio-5000-emulator/82916>\
**Created:** [December 8, 2023, 8:06pm UTC](https://forum.inductiveautomation.com/t/ignition-and-studio-5000-emulator/82916 "2023-12-08T20:06:12Z")\
**Showing post:** 3
**Author:** ![amarks](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/amarks/32/45610_2.png) [@amarks](https://forum.inductiveautomation.com/u/amarks)\
**Post date:** [December 8, 2023, 10:39pm UTC](https://forum.inductiveautomation.com/t/ignition-and-studio-5000-emulator/82916/3 "2023-12-08T22:39:17Z")
If you're just looking to verify OPC paths, just export to L5X (after disabling any source protection) and use @pturmel's [Ethernet/IP module](https://forum.inductiveautomation.com/t/automation-professionals-ethernet-ip-communication-suite-v2/68190) to import the L5X into a host device.
You won't get any sort of IO simulation, as if simulating a PLC, but your connections will work and you can change tag values and watch the changes happen in real-time.
Also note, small difference with how [arrays of BOOLs](https://forum.inductiveautomation.com/t/logix-driver-vs-ethip-driver-array-of-bools/81964) are handled in the Logix driver and Phil's module.
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-and-studio-5000-emulator/82916)._
