# Ignition as WebSocket client
**URL:** <https://forum.inductiveautomation.com/t/ignition-as-websocket-client/112935>\
**Tags:** ignition83\
**Created:** [December 21, 2025, 8:43am UTC](https://forum.inductiveautomation.com/t/ignition-as-websocket-client/112935 "2025-12-21T08:43:30Z")\
**Post date:** [December 21, 2025, 2:39pm UTC](https://forum.inductiveautomation.com/t/ignition-as-websocket-client/112935/2 "2025-12-21T14:39:13Z")
Possible with jython scripts.
> [@WebSocket Client](https://forum.inductiveautomation.com/t/websocket-client/44447/21):
> Merged at this point from here: So after clarifying some additional code that was needed and running from the correct gateway context, it works! This means we have a way to get data into Ignition from massive Kafka topics by using the lenses SQL api mentioned here: [https://api.lenses.io/branches/4.3/index.html#data-access-query-data-via-sql-get](https://api.lenses.io/branches/4.3/index.html#data-access-query-data-via-sql-get) There were a few more things required, namely encoding the text you send and conversion of the return (here I just put it to string so as…
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-as-websocket-client/112935)._
