# Ignition behind an apache reverse proxy, issue with perspective views
**URL:** <https://forum.inductiveautomation.com/t/ignition-behind-an-apache-reverse-proxy-issue-with-perspective-views/53576>\
**Tags:** ignition81\
**Created:** [November 30, 2021, 4:23pm UTC](https://forum.inductiveautomation.com/t/ignition-behind-an-apache-reverse-proxy-issue-with-perspective-views/53576 "2021-11-30T16:23:04Z")\
**Showing post:** 5
**Author:** ![Massimo\_Forni](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/massimo_forni/32/29925_2.png) [@Massimo\_Forni](https://forum.inductiveautomation.com/u/Massimo_Forni)\
**Post date:** [March 8, 2022, 7:31am UTC](https://forum.inductiveautomation.com/t/ignition-behind-an-apache-reverse-proxy-issue-with-perspective-views/53576/5 "2022-03-08T07:31:03Z")
In the end I used NGINX and it worked the first time
Her for the community my conf file, I hope this will be useful for others:
```auto
upstream ignition_http {
    keepalive 20;
    server 127.0.0.1:8088;
server {
    listen 80;
    return 301 https://$host$request_uri/;
server {
    listen 443 http2 ssl;
    listen [::]:443 http2 ssl;
    server_name YOUR_SERVER_FQDN;
    ssl_certificate PATH_TO_PUBLIC_CHAIN;
    ssl_certificate_key PATH_TO_PRIVATE_KEY;
    location / {
        proxy_http_version 1.1;
        proxy_cache_bypass $http_upgrade;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "Upgrade";
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Port $server_port;
        proxy_pass http://ignition_http;
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-behind-an-apache-reverse-proxy-issue-with-perspective-views/53576)._
