# Ignition Client Performance Issues
**URL:** <https://forum.inductiveautomation.com/t/ignition-client-performance-issues/84120>\
**Created:** [January 11, 2024, 4:22pm UTC](https://forum.inductiveautomation.com/t/ignition-client-performance-issues/84120 "2024-01-11T16:22:52Z")\
**Showing post:** 6
**Post date:** [January 11, 2024, 4:37pm UTC](https://forum.inductiveautomation.com/t/ignition-client-performance-issues/84120/6 "2024-01-11T16:37:14Z")
1. That's a painful load situation for a reasonable number of tags. You should study this topic and some of the links therein:
> [@Cannot read some tags inside Rockwell AOI](https://forum.inductiveautomation.com/t/cannot-read-some-tags-inside-rockwell-aoi/38393):
> I am trying to see tags inside an AOI. I went back to basics and dragged and dropped the tags from the OPC browser into the Tags Folder, but the quality is bad and there is a red x next to them. What is more confusing is that some are working and some are not. I cannot see any similarities between the few that aren’t working. Data type, In and Out types are working and not working. I can create a new UDT as an In/Out but this seems cumbersome. In this case, I would need to create tags only fo…
You may also find this topic helpful:
> [@Automation Professionals' EtherNet/IP Communication Suite V2](https://forum.inductiveautomation.com/t/automation-professionals-ethernet-ip-communication-suite-v2/68190):
> Automation Professionals is pleased to announce its latest EtherNet/IP Communications Suite driver module, a major upgrade to its EtherNet/IP Class1 Communications module, as a Public Beta. As of April 15, 2023, this is now a Production Release. The primary new feature is its new Generic EtherNet/IP Client Driver, a drop-in replacement for IA's Logix V21+ driver and its Omron NJ/NX driver. It does work with older Logix processors, and also works with Rockwell's MicroLogix 8xx family (ethernet…
{ /shameless plug }
However, this:
> [@Stephen\_Smith](#):
> the clients "freeze" and must be re-started at least daily
Sounds like a memory leak or badly-behaved foreground script in a Vision client. That is much more trouble to find and fix--possibly requiring some redesign.
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-client-performance-issues/84120)._
