Ignition images: http://localhost/imagename
ignition80
#1
I have a ton of images that i use with ignition, setting the file path appears to be using my PC to utilize.
I installed a webserver on the ignition server and would effectively like to use it as an image repository that is not accessible from the internet.
Is there a way to set the filepath on images to http://localhost/, simliar to builtin.
If there wasn’t 1000s of images, I’d use the builtin feature.
#2
Yes, if I understand you correctly you can place your images or folder of images inside the install directory of the gateway inside of <install_directory>/webserver/webapps/main and after a gateway restart they are hosted at http://localhost:8088/<path_to_image> and don’t forget to include the image extension in the path (ie. the .jpg, .png, etc)
#3
Placing files in that path does allow my webbrowser to access the filename.jpg, but localhost won’t work from within ignition, i still need to define an external IP
#4
Can you give me an example? Are you using this on an image component on Vision or Perspective? Also, when you have a session/client opened are they on the same system as the gateway since that’s the only time localhost should work?
