# Ignition Perspective symbol factory animation
**URL:** <https://forum.inductiveautomation.com/t/ignition-perspective-symbol-factory-animation/36119>\
**Created:** [June 27, 2020, 5:09pm UTC](https://forum.inductiveautomation.com/t/ignition-perspective-symbol-factory-animation/36119 "2020-06-27T17:09:11Z")\
**Showing post:** 7
**Author:** ![nader.chinichian](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/nader.chinichian/32/9261_2.png) [@nader.chinichian](https://forum.inductiveautomation.com/u/nader.chinichian)\
**Post date:** [June 28, 2020, 5:20am UTC](https://forum.inductiveautomation.com/t/ignition-perspective-symbol-factory-animation/36119/7 "2020-06-28T05:20:20Z")
Personally I believe there is no good library out there so I use P&ID and try to mimic symbol form it to get my own library.
Take a look a following post to see what I mean of drawing.
If you use my workflow the perspective will be create.
Use inkscape it is easy and professional.
> [@Embedded view doesn't render on view startup](http://forum.inductiveautomation.com/t/embedded-view-doesnt-render-on-view-startup/35907):
> Hi In views with many embedded view objects(more than 80), when opening the view some of the embedded view randomly doesn’t render at all. Even refreshing the page doesn’t fix this and only randomly some other embedded views doesn’t render each time. I can see this bug in every devices even powerful ones and even in designer. It seems there is timeout involve and when the client doesn’t get embedded view data, ignition ignore them. I test it on 8.0.12 and 8.0.13. …
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-perspective-symbol-factory-animation/36119)._
