# Ignition Server Memory Spike
**URL:** <https://forum.inductiveautomation.com/t/ignition-server-memory-spike/19356>\
**Tags:** ignition79\
**Created:** [August 22, 2018, 11:10am UTC](https://forum.inductiveautomation.com/t/ignition-server-memory-spike/19356 "2018-08-22T11:10:15Z")\
**Showing post:** 7
**Author:** ![witman](https://avatars.discourse-cdn.com/v4/letter/w/d2c977/32.png) [@witman](https://forum.inductiveautomation.com/u/witman)\
**Post date:** [April 15, 2019, 5:06pm UTC](https://forum.inductiveautomation.com/t/ignition-server-memory-spike/19356/7 "2019-04-15T17:06:48Z")
See `wrapper.java.additional.3, 6, 7, & 8` in this post:
> [@Gateway / Java question 7.7.2](http://forum.inductiveautomation.com/t/gateway-java-question-7-7-2/10402/2):
> It is normal for Ignition (and java in general) to cycle between low and high memory usage. In a nutshell, java will defer difficult garbage collection tasks until memory pressure makes it necessary. If there is a great deal of garbage objects when that happens, java will stall briefly while it frees memory. If you have tweaked anything else on your system, you are probably still running what is called the Concurrent-Mark-Sweep garbage collection algorithm (standard for java7). A new garbage…
Also see the the section shown below [here](https://www.oracle.com/webfolder/technetwork/tutorials/obe/java/G1GettingStarted/index.html):
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/2X/7/722d7500815c461b1f758729b051a81d1de4396c.png)
_[View the full topic](https://forum.inductiveautomation.com/t/ignition-server-memory-spike/19356)._
