# Improve column resizing on SQLTags browser
**URL:** <https://forum.inductiveautomation.com/t/improve-column-resizing-on-sqltags-browser/8535>\
**Created:** [June 8, 2014, 1:27am UTC](https://forum.inductiveautomation.com/t/improve-column-resizing-on-sqltags-browser/8535 "2014-06-08T01:27:54Z")\
**Posts on this page:** 2\
**Author:** ![miketob](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/miketob/32/5936_2.png) [@miketob](https://forum.inductiveautomation.com/u/miketob)\
**Post date:** [June 8, 2014, 1:27am UTC](https://forum.inductiveautomation.com/t/improve-column-resizing-on-sqltags-browser/8535/1 "2014-06-08T01:27:54Z")
Hello,
It would be great if it was possible to adjust the column size in the SQLTags browser window not only using the headers but dragging any column division line.
When I’m looking at a tag that is at the very bottom of the list, and I need to see the value or quality I need to resize the columns, so I have to go all the way up to reach the header, then, resize the column, and then go all the way down to the tag I was looking at. that’s pretty annoying. On the other hand, the property editor window works great in this matter!
Thank you
**Author:** ![JGJohnson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jgjohnson/32/29582_2.png) [@JGJohnson](https://forum.inductiveautomation.com/u/JGJohnson)\
**Post date:** [June 9, 2014, 1:18pm UTC](https://forum.inductiveautomation.com/t/improve-column-resizing-on-sqltags-browser/8535/2 "2014-06-09T13:18:28Z")
My workaround for this is to use the “toggle floating” button to detach it from main window. And even then it usually doesn’t size the columns correctly until you click on the vertical slider.
