# Insert into the database from 2 different sources
**URL:** <https://forum.inductiveautomation.com/t/insert-into-the-database-from-2-different-sources/51997>\
**Tags:** perspective\
**Created:** [October 15, 2021, 4:50pm UTC](https://forum.inductiveautomation.com/t/insert-into-the-database-from-2-different-sources/51997 "2021-10-15T16:50:28Z")\
**Showing post:** 14
**Author:** ![Rahul\_Bhakte1](https://avatars.discourse-cdn.com/v4/letter/r/c89c15/32.png) [@Rahul\_Bhakte1](https://forum.inductiveautomation.com/u/Rahul_Bhakte1)\
**Post date:** [September 21, 2023, 7:27am UTC](https://forum.inductiveautomation.com/t/insert-into-the-database-from-2-different-sources/51997/14 "2023-09-21T07:27:23Z")
Hello, I am facing the similar issue. That I want to insert entire dataset into database table.
I followed the code by @lrose but getting below error.
Code:
```auto
data1 = system.tag.read("[default]TEST/Tag").value
pyData = system.dataset.toPyDataSet(data1)
query = "INSERT INTO MyTable (C1, C2, C3, C4, C5, C6, C7) VALUES %s"
valueArgs = ','.join(['(?,?,?,?,?,?,?)'] * data1.getRowCount())
argList = [row for row in pyData]
system.db.runPrepUpdate(query % valueArgs, argList, 'MyDB')
Error:
```auto
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to decode arguments
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:288)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:261)
	... 23 more
Caused by: java.io.InvalidClassException: failed to read class descriptor
I am not sure what I am missing here.
_[View the full topic](https://forum.inductiveautomation.com/t/insert-into-the-database-from-2-different-sources/51997)._
