# IP camera status - how to catch "Stream ended." status
**URL:** <https://forum.inductiveautomation.com/t/ip-camera-status-how-to-catch-stream-ended-status/18030>\
**Created:** [May 15, 2018, 1:03am UTC](https://forum.inductiveautomation.com/t/ip-camera-status-how-to-catch-stream-ended-status/18030 "2018-05-15T01:03:03Z")\
**Showing post:** 9
**Post date:** [May 12, 2020, 12:22pm UTC](https://forum.inductiveautomation.com/t/ip-camera-status-how-to-catch-stream-ended-status/18030/9 "2020-05-12T12:22:31Z")
Looks familiar.... If you look at the Usage Notes for my Image Streamer module, you'll see a formal version of this as a script module, suited to use in a binding. Allows you to copy camera view instances around without needing a separate timer component.
[https://www.automation-pros.com/streamer/doc/](https://www.automation-pros.com/streamer/doc/)
Also:
> [@Automation Professionals' Image Streamer Driver Module](http://forum.inductiveautomation.com/t/automation-professionals-image-streamer-driver-module/29371):
> Automation Professionals is pleased to announce a Release Candidate for its new driver module, supporting the live Network Image transmission format of [Keyence CV-5000](https://www.keyence.com/products/vision/vision-sys/cv-5000/index.jsp) machine vision controllers, plus support for common Network Video streams via [OpenCV](https://opencv.org/). Stream metadata is exposed as OPC items, and the output streams are Motion JPEG. The IP Camera Viewer Component in Vision can consume these streams, making it possible to integrate IP Cameras that don't have MJPEG support or have poor support f…
_[View the full topic](https://forum.inductiveautomation.com/t/ip-camera-status-how-to-catch-stream-ended-status/18030)._
