# Is there a known problem with Ignition 8.0 Launcher icons?
**URL:** <https://forum.inductiveautomation.com/t/is-there-a-known-problem-with-ignition-8-0-launcher-icons/39072>\
**Created:** [September 25, 2020, 4:29pm UTC](https://forum.inductiveautomation.com/t/is-there-a-known-problem-with-ignition-8-0-launcher-icons/39072 "2020-09-25T16:29:10Z")\
**Post date:** [September 25, 2020, 5:14pm UTC](https://forum.inductiveautomation.com/t/is-there-a-known-problem-with-ignition-8-0-launcher-icons/39072/2 "2020-09-25T17:14:57Z")
Do you have something like this on the internalFrameActivated event of navigation pane? That should take care of the window and taskbar.
> [@How to change icon appearing on the taskbar?](http://forum.inductiveautomation.com/t/how-to-change-icon-appearing-on-the-taskbar/8707/8):
> After upgraded to 7.7, the above script didn’t work. Jae helped me get around by providing this script to me. Forgot to mention that, put this script under visionWindowOpened event from javax.imageio import ImageIO from [java.net](http://java.net) import URL from javax.swing import JFrame from org.python.core import Py url16 = URL(“[http://localhost:8088/main/system/images/Builtin/icons/16/add2.png](http://localhost:8088/main/system/images/Builtin/icons/16/add2.png)”) url32 = URL(“[http://localhost:8088/main/system/images/Builtin/icons/32/add2.png](http://localhost:8088/main/system/images/Builtin/icons/32/add2.png)”) url48 = URL(“[http://localh…](http://localhost:8088/main/system/images/Builtin/icons/48/add2.png)
I think it's been mentioned before that shortcut icon created by the launcher ignores the application icon, but uses the stock ignition icon.
_[View the full topic](https://forum.inductiveautomation.com/t/is-there-a-known-problem-with-ignition-8-0-launcher-icons/39072)._
