# Issues when using system.util.invokeAsynchronous() I get a 'NoneType' object is not callable error
**URL:** <https://forum.inductiveautomation.com/t/issues-when-using-system-util-invokeasynchronous-i-get-a-nonetype-object-is-not-callable-error/97022>\
**Tags:** perspective, scripting\
**Created:** [October 9, 2024, 2:06pm UTC](https://forum.inductiveautomation.com/t/issues-when-using-system-util-invokeasynchronous-i-get-a-nonetype-object-is-not-callable-error/97022 "2024-10-09T14:06:44Z")\
**Showing post:** 7
**Post date:** [October 9, 2024, 2:25pm UTC](https://forum.inductiveautomation.com/t/issues-when-using-system-util-invokeasynchronous-i-get-a-nonetype-object-is-not-callable-error/97022/7 "2024-10-09T14:25:28Z")
That doesn't really mean anything:
> [@Event Configuration Print Out to debug](https://forum.inductiveautomation.com/t/event-configuration-print-out-to-debug/60091/5):
> It’s complicated slight_smile Starting from most local to least… In the script console, print will log directly to the output buffer on the right hand side. system.util.getLogger() will log to the named ‘Output Console’ Designer window. Bonus: A script invoked from here using system.util.invokeAsync will print to the regular output console, not the buffer on the right hand side. Anywhere else in the designer (except Perspective), print and system.util.getLogger will log to the ‘Out…
Post your updated code.
_[View the full topic](https://forum.inductiveautomation.com/t/issues-when-using-system-util-invokeasynchronous-i-get-a-nonetype-object-is-not-callable-error/97022)._
