# Issues with docked window resize
**URL:** <https://forum.inductiveautomation.com/t/issues-with-docked-window-resize/53533>\
**Created:** [November 25, 2021, 5:17pm UTC](https://forum.inductiveautomation.com/t/issues-with-docked-window-resize/53533 "2021-11-25T17:17:12Z")\
**Showing post:** 4
**Post date:** [June 3, 2025, 2:41pm UTC](https://forum.inductiveautomation.com/t/issues-with-docked-window-resize/53533/4 "2025-06-03T14:41:10Z")
You would have to reach "into" the tab strip component and provide your own widths to the component; it doesn't automatically scale its inner components to fill in the way you're expecting.
There's a hack of sorts to accomplish this via the tab attributes dataset documented here:
> [@Multiple Tab Strips - Consistent Tab Button Sizing](https://forum.inductiveautomation.com/t/multiple-tab-strips-consistent-tab-button-sizing/81230):
> For those who are looking to use multiple tab strips for tier navigation, or other things, I wanted to share a quick tip because getting them all to size the same between the different strips can be a hassle if display names change, etc. What I've done is created an extra, disabled tab at the very end of the strip that has transparent background color. It's display name is \<html\>\<font style="font-size:0px"\>long display name - tab size is deteremined by the maximum display name and the text pad…
Or this thread has a different, more "imperative" approach involving scripting to directly modify the inner components. The script in this post is modifying the overflow arrow panels, but it could be modified to look for the inner `com.inductiveautomation.factorypmi.application.components.tabstrip.TabComponent` instead pretty easily.
> [@Tag Strip Feature Request to make scroll arrows wider](https://forum.inductiveautomation.com/t/tag-strip-feature-request-to-make-scroll-arrows-wider/57177/7):
> I'm pretty sure that is the scrollbar. If you must adjust your arrow button size with scripting, here is a simple recursive function that will do it: from com.inductiveautomation.factorypmi.application.components.util import HoldDownArrowButton from com.inductiveautomation.factorypmi.application.components.tabstrip import LeftRightArrowPanel from java.awt import Dimension tabStrip = system.gui.getParentWindow(event).getComponentForPath('Root Container.Tab Strip') arrowHeight = 50 arrowWidth =…
_[View the full topic](https://forum.inductiveautomation.com/t/issues-with-docked-window-resize/53533)._
