# jxbrowser.chromium.BrowserException on macOS 10.15.4
**URL:** <https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835>\
**Created:** [April 9, 2020, 10:42pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835 "2020-04-09T22:42:14Z")\
**Posts on this page:** 11\
**Author:** ![hunterdg](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/hunterdg/32/67774_2.png) [@hunterdg](https://forum.inductiveautomation.com/u/hunterdg)\
**Post date:** [April 9, 2020, 10:42pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/1 "2020-04-09T22:42:14Z")
Surely related to: [[Bug] Embedded browser fails to correctly start on b2019030502](http://forum.inductiveautomation.com/t/bug-embedded-browser-fails-to-correctly-start-on-b2019030502/23065), would’ve commented there but thread is locked.
my last Ignition install was 8.0.5 on Server 2016, working well then, but haven’t touched it until new install yesterday of 8.0.10 on Server 2019.
Replaced Designer Launcher (macOS) with new from 8.0.10 gateway, now can’t open **any** Perspective views on **either** Ignition instance.
Renamed `.ignition` to `.ignition.old` for good measure, no effect.
Log:
```auto
com.teamdev.jxbrowser.chromium.BrowserException: Failed to initialize or establish a connection with a Chromium render process. You are observing this exception as the render process didn't respond within 120 seconds after the Browser constructor has been invoked.
	at com.teamdev.jxbrowser.chromium.Browser.<init>(SourceFile:4687)
	at com.teamdev.jxbrowser.chromium.Browser.<init>(SourceFile:357)
	at com.inductiveautomation.perspective.designer.workspace.design.BrowserPanel.<init>(BrowserPanel.java:121)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.init(ViewResourceEditor.java:312)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.init(ViewResourceEditor.java:60)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.loadResource(ResourceEditor.java:58)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.lambda$new$0(ResourceEditor.java:37)
	at java.base/java.util.Optional.ifPresent(Unknown Source)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.<init>(ResourceEditor.java:35)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.<init>(ViewResourceEditor.java:103)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.newResourceEditor(ViewWorkspace.java:316)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.open(TabbedResourceWorkspace.java:227)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.PagesConfigPanel$PageList.lambda$openViewIfExists$3(PagesConfigPanel.java:214)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.PagesConfigPanel$PageList.openViewIfExists(PagesConfigPanel.java:214)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.PagesConfigPanel$PageList.lambda$new$2(PagesConfigPanel.java:204)
	at com.inductiveautomation.ignition.client.util.gui.Listen$2.mousePressed(Listen.java:66)
	at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.0.10 (b2020031912)
Java: Azul Systems, Inc. 11.0.6
Separate issue: have this error when launching designer after creating new project from “Dashboard” template:
```auto
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:valueChanged>", line 2, in valueChanged
AttributeError: 'NoneType' object has no attribute 'value'
	at org.python.core.Py.AttributeError(Py.java:207)
	at org.python.core.PyObject.noAttributeError(PyObject.java:1032)
	at org.python.core.PyObject. __getattr__ (PyObject.java:1027)
	at org.python.pycode._pyx43.valueChanged$1(<function:valueChanged>:3)
	at org.python.pycode._pyx43.call_function(<function:valueChanged>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
	at org.python.core.PyFunction.function ___call__ (PyFunction.java:471)
	at org.python.core.PyFunction. __call__ (PyFunction.java:466)
	at org.python.core.PyFunction. __call__ (PyFunction.java:456)
	at org.python.core.PyFunction. __call__ (PyFunction.java:451)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:798)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:675)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:927)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:740)
	at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:97)
	at com.inductiveautomation.perspective.gateway.model.PropertyChangeScript.onValueChanged(PropertyChangeScript.java:104)
	at com.inductiveautomation.perspective.gateway.property.PropertyTree$Notifier.run(PropertyTree.java:185)
	at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:204)
Caused by: org.python.core.PyException
	... 22 more
**Post date:** [April 9, 2020, 11:04pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/2 "2020-04-09T23:04:53Z")
I don’t think you’ll be able to run the designer or browser component on Server 2019 until we finish the JXBrowser upgrade. Their release notes say version 7.4 officially supports Server 2019 and that’s the version we’re working on integrating.
**Post date:** [April 10, 2020, 12:04am UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/3 "2020-04-10T00:04:46Z")
Clarification, Designer Launcher is running on macOS Catalina 10.15.4, connected to Server 2019/2016 gateways - does the same limitation you described above apply to this version of macOS?
**Post date:** [April 10, 2020, 12:51am UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/4 "2020-04-10T00:51:19Z")
No, should work fine on 10.15.4. Probably half our developers are using macOS without issues.
@PerryAJ do you know what this is about?
**Post date:** [April 10, 2020, 8:39pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/5 "2020-04-10T20:39:07Z")
Can’t duplicate this issue after installing macOS Catalina 10.15.4 Supplemental Update
**Post date:** [April 10, 2020, 8:53pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/6 "2020-04-10T20:53:09Z")
Might have just been the reboot that helped. Let us know if you see it again.
**Post date:** [April 21, 2020, 2:46am UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/7 "2020-04-21T02:46:29Z")
Happened again, reboot (of my mac) resolved. Strange. Also had some issues renaming “template” views referenced by other views - got spinning ball of death, force-quit designer b/c I was impatient. Those issues also seem to be resolved after reboot. Can’t reproduce now, though I’ve recreated/saved those views in question - crash happened while they were newly created/unsaved to gateway.
When I first re-launched designer/connected to gateway after reboot, instead of auth dialog straightaway, got a “downloading…” dialog (as if it was first time connecting to gateway), but only seemed to download a couple files, then presented auth dialog. I had previously restored a project backup, but had also already tried to open it (concurrently with an existing designer session - that’s when i got the "unable to deserialize) error again, so can’t imagine it was re-downloading the project.
Will report back if I experience it again, and will hopefully be able to reproduce.
Currently using launcher 1.0.10 to access both 8.0.5 and 8.0.10 gateways
**Post date:** [April 29, 2020, 8:37pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/8 "2020-04-29T20:37:07Z")
here’s the error I get when renaming an un-saved view:
```auto
com.teamdev.jxbrowser.chromium.internal.ipc.IPCException: Failed to get Browser browserChannel 6
	at com.teamdev.jxbrowser.chromium.Browser.a(SourceFile:496)
	at com.teamdev.jxbrowser.chromium.Browser.<init>(SourceFile:410)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceNode.open(ResourceNode.java:126)
**Post date:** [April 29, 2020, 8:40pm UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/9 "2020-04-29T20:40:25Z")
Happens concurrently with another designer instance experiencing the failure to open existing views (same gateway, different project).
reboot resolves. I’m baffled.
```auto
	at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:295)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:675)
**Post date:** [April 30, 2020, 12:13am UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/10 "2020-04-30T00:13:16Z")
Think I’ve found the culprit - seems that Better Touch Tool’s “Doubleclick Main Menubar” trigger conflicts with Ignition Designer somehow.
[Bug Report](https://community.folivora.ai/t/doubleclick-main-menubar-trigger-conflicts-with-inductive-automation-ignition-designer/15694)
[Imgur](https://imgur.com/9sR9tvs)
**Post date:** [April 30, 2020, 12:21am UTC](https://forum.inductiveautomation.com/t/jxbrowser-chromium-browserexception-on-macos-10-15-4/33835/11 "2020-04-30T00:21:52Z")
What the… 😕
