# Loading Performance Problems with Perspective bindings
**URL:** <https://forum.inductiveautomation.com/t/loading-performance-problems-with-perspective-bindings/112567>\
**Tags:** perspective, ignition81\
**Created:** [December 2, 2025, 2:18pm UTC](https://forum.inductiveautomation.com/t/loading-performance-problems-with-perspective-bindings/112567 "2025-12-02T14:18:32Z")\
**Showing post:** 6
**Post date:** [December 2, 2025, 4:50pm UTC](https://forum.inductiveautomation.com/t/loading-performance-problems-with-perspective-bindings/112567/6 "2025-12-02T16:50:48Z")
> [@danielps1818](#):
> static simple gauges take about 5 seconds to load.
The static gauges are a bit notorious for being slow, to the point that many use a script transform on an embedded svg instead.
> [@Perspective, faster page](https://forum.inductiveautomation.com/t/perspective-faster-page/69885/35):
> Okay, I had a bit of free time today, so here is a complete SVG solution. You could do the Label as SVG text as well, or a gauge needle if you wanted, I haven't gone that far. Just a little example of the power of using the Ignition Designer to add SVG elements. I didn't include the label for the example. Note: All of this (outside of the calculations needed to find the points for the shape) was done inside of the designer (yes I can be somewhat of a masochist at times. rofl). First a s…
I would recommend making the script part of the transform a function in the project library for easy re-use(and to avoid having to `import` inside of a function).
_[View the full topic](https://forum.inductiveautomation.com/t/loading-performance-problems-with-perspective-bindings/112567)._
