# Module deploy problem in Ignition server with ANT
**URL:** <https://forum.inductiveautomation.com/t/module-deploy-problem-in-ignition-server-with-ant/7520>\
**Category:** 3rd Party Modules\
**Created:** [November 5, 2013, 3:07pm UTC](https://forum.inductiveautomation.com/t/module-deploy-problem-in-ignition-server-with-ant/7520 "2013-11-05T15:07:00Z")\
**Posts on this page:** 2\
**Author:** ![marcel.forbes](https://avatars.discourse-cdn.com/v4/letter/m/65b543/32.png) [@marcel.forbes](https://forum.inductiveautomation.com/u/marcel.forbes)\
**Post date:** [November 5, 2013, 3:07pm UTC](https://forum.inductiveautomation.com/t/module-deploy-problem-in-ignition-server-with-ant/7520/1 "2013-11-05T15:07:00Z")
Inside Eclipse and using ant, after built the file module example, the “deploy” script task cannt deploy to the server; this has 7.6.3 version trail.
deploy:
[echo] Installing SimpleTagProvider Example on Ignition Gateway.
[postmodule] moduleFile=D:\Desarrollo\Java\Ignition\SimpleTagProviderExample\Build\modules\SimpleTagProvider Example-unsigned.modl, postUrl=http://10.119.0.163:8088/main/system/DeveloperModuleLoadingServlet
BUILD FAILED
D:\Desarrollo\Java\Ignition\SimpleTagProviderExample\Build\build.xml:80: java.io.FileNotFoundException: [10.119.0.163:8088/main/system/De … ingServlet](http://10.119.0.163:8088/main/system/DeveloperModuleLoadingServlet)
**Post date:** [November 5, 2013, 3:16pm UTC](https://forum.inductiveautomation.com/t/module-deploy-problem-in-ignition-server-with-ant/7520/2 "2013-11-05T15:16:03Z")
You need to have a gateway with a developer license activated on it to install unsigned modules. See if this form still works: [inductiveautomation.com/developers](https://inductiveautomation.com/developers)
If not, contact your sales rep.
