# MQTT Transmission UDT metadata not updating MQTT Engine
**URL:** <https://forum.inductiveautomation.com/t/mqtt-transmission-udt-metadata-not-updating-mqtt-engine/67639>\
**Category:** 3rd Party Modules\
**Tags:** ignition81\
**Created:** [December 14, 2022, 10:43pm UTC](https://forum.inductiveautomation.com/t/mqtt-transmission-udt-metadata-not-updating-mqtt-engine/67639 "2022-12-14T22:43:46Z")\
**Author:** ![justin.brzozoski](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/justin.brzozoski/32/13452_2.png) [@justin.brzozoski](https://forum.inductiveautomation.com/u/justin.brzozoski)\
**Post date:** [December 15, 2022, 4:41am UTC](https://forum.inductiveautomation.com/t/mqtt-transmission-udt-metadata-not-updating-mqtt-engine/67639/2 "2022-12-15T04:41:36Z")
If this is on 8.1.22 it may be a regression bug. Check your logs for errors like "Error processing edit for tag path" discussed towards the end of this thread (the top of the thread has to do with unrelated EAM issues and you can ignore it):
> [@\[BUG\] EAM - Tag copy task failed due to insufficient tag provider edit permissions](https://forum.inductiveautomation.com/t/eam-tag-copy-task-failed-due-to-insufficient-tag-provider-edit-permissions/66910/17):
> Sorry to possibly hijack a thread, but we upgraded our production server to 8.1.22 yesterday and very similar errors as what @nminchin is getting later in this thread started showing up in our logs. We are not using EAM. Our errors all seem to be immediately after a Sparkplug edge node rebirths, when MQTT Engine is trying to merge any property changes into the tag: INFO | jvm 1 | 2022/12/05 15:47:27 | E [t.m.provider] [15:47:27]: Error encountered processing tag edit prov…
_[View the full topic](https://forum.inductiveautomation.com/t/mqtt-transmission-udt-metadata-not-updating-mqtt-engine/67639)._
