# MySQL5.6 error OPTION SQL\_SELECT\_LIMIT=1
**URL:** <https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248>\
**Created:** [April 17, 2013, 9:53am UTC](https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248 "2013-04-17T09:53:20Z")\
**Posts on this page:** 4\
**Author:** ![mazeyrat](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/mazeyrat/32/10955_2.png) [@mazeyrat](https://forum.inductiveautomation.com/u/mazeyrat)\
**Post date:** [April 17, 2013, 9:53am UTC](https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248/1 "2013-04-17T09:53:20Z")
I use ignition 7.6 beta and mysql 5.6 32 bits on windows 7.
I have the following error :
com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘OPTION SQL\_SELECT\_LIMIT=1’ at line 1
[quote]
Time Logger Message
[ERROR] 11:46:13 StoreAndForward.histo\_eco2c.TagHistoryDatasourceSink Error initializing data sink.
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:936)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2934)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1616)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1708)
at com.mysql.jdbc.Connection.execSQL(Connection.java:3249)
at com.mysql.jdbc.Connection.execSQL(Connection.java:3178)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1408)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:93)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeQuery(SRConnectionWrapper.java:808)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runScalarPrepQuery(SRConnectionWrapper.java:193)
at com.inductiveautomation.ignition.gateway.sqltags.history.storage.TagHistoryDatasourceSink.getDriverId(TagHistoryDatasourceSink.java:336)
at com.inductiveautomation.ignition.gateway.sqltags.history.storage.TagHistoryDatasourceSink.createPartitionManager(TagHistoryDatasourceSink.java:247)
at com.inductiveautomation.ignition.gateway.sqltags.history.storage.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:219)
at com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.tryToInit(AbstractSink.java:112)
at com.inductiveautomation.ignition.gateway.sqltags.history.storage.TagHistoryDatasourceSink.tryToInit(TagHistoryDatasourceSink.java:208)
at com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.isAccepting(AbstractSink.java:129)
at com.inductiveautomation.ignition.gateway.history.sinks.AbstractDatasourceSink.isAccepting(AbstractDatasourceSink.java:82)
at com.inductiveautomation.ignition.gateway.sqltags.history.storage.TagHistoryDatasourceSink.isAccepting(TagHistoryDatasourceSink.java:285)
at com.inductiveautomation.ignition.gateway.history.sinks.AggregateSink.isAccepting(AggregateSink.java:88)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:122)
(I) 11:46:13 StoreAndForward.histo\_eco2c.TagHistoryDatasourceSink SQLTags history tables verified successfully.
[ERROR] 11:45:43 StoreAndForward.histo\_eco2c.TagHistoryDatasourceSink Error initializing data sink.
[/quote]
I use the last mysql-connector-java-5.1.23-bin.jar jdbc driver.
I’v read “OPTION SQL\_SELECT\_LIMIT=1” must be replace by “SET SQL\_SELECT\_LIMIT=1;”
how to solve this pb ???
**Author:** ![gnguyen](https://avatars.discourse-cdn.com/v4/letter/g/41988e/32.png) [@gnguyen](https://forum.inductiveautomation.com/u/gnguyen)\
**Post date:** [April 17, 2013, 10:23am UTC](https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248/2 "2013-04-17T10:23:08Z")
This is a common pb with MySQL 5.6 ; just update the jar jdbc connector :
- download from this place : [mysql.com/downloads/connector/j/](http://www.mysql.com/downloads/connector/j/)
- and extract the “mysql-connector-java-5.X.XX-bin.jar” from the zip
- go to the gateway configuration page and edit the driver (database\>drivers)
- et voilà
Hope this help
**Post date:** [April 17, 2013, 12:24pm UTC](https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248/3 "2013-04-17T12:24:39Z")
I’ve update to mysql-connector-java-5.1.24-bin.jar
restarted the gateway
but I’ve always the same error message ?? ![:scratch:](https://us1.discourse-cdn.com/inductiveautomation/original/1X/76d1620bec252bfac07050c889ff5a91dc8a9c25.gif ":scratch:")
**Post date:** [April 17, 2013, 1:13pm UTC](https://forum.inductiveautomation.com/t/mysql5-6-error-option-sql-select-limit-1/6248/4 "2013-04-17T13:13:02Z")
Yes it’s ok, after reloading the jar and restarting the gateway and cleaning the store and forward cache
