# Named Queries VARCHAR Error
**URL:** <https://forum.inductiveautomation.com/t/named-queries-varchar-error/90307>\
**Created:** [May 13, 2024, 1:41pm UTC](https://forum.inductiveautomation.com/t/named-queries-varchar-error/90307 "2024-05-13T13:41:08Z")\
**Showing post:** 24
**Post date:** [May 14, 2024, 11:46am UTC](https://forum.inductiveautomation.com/t/named-queries-varchar-error/90307/24 "2024-05-14T11:46:39Z")
> [@Transistor](#):
> fires off the script from the library and lets go.
No. You might be confusing libraries with the technique I recommend in this topic:
> [@Java concurrent queue for tag change scripts](https://forum.inductiveautomation.com/t/java-concurrent-queue-for-tag-change-scripts/82044):
> Continuing the discussion from [[SOLVED] Are tag Value Changed scripts running asynchronously?](https://forum.inductiveautomation.com/t/solved-are-tag-value-changed-scripts-running-asynchronously/68704/5): We've got code in our standard library that I need to log a value change on a tag and then associate various data points with that value change. The value is located in a UDT, and because this is part of our "standard" library we use for our customers, the number of tags is variable and quite possibly numerous so having a gateway tag event script isn't feasible for this solution. I was reading up on …
Using `queueUtil` **does** push the work out of the tag event thread pool.
_[View the full topic](https://forum.inductiveautomation.com/t/named-queries-varchar-error/90307)._
