# Numeric Text Field - Float vs Double Issue
**URL:** <https://forum.inductiveautomation.com/t/numeric-text-field-float-vs-double-issue/117737>\
**Tags:** vision\
**Created:** [November 4, 2026, 2:41pm UTC](https://forum.inductiveautomation.com/t/numeric-text-field-float-vs-double-issue/117737 "2026-11-04T14:41:47Z")\
**Showing post:** 6
**Post date:** [November 4, 2026, 5:44pm UTC](https://forum.inductiveautomation.com/t/numeric-text-field-float-vs-double-issue/117737/6 "2026-11-04T17:44:21Z")
This is a known/accepted issue in Vision's numeric text field component; if you want to talk to support you can reference our internal ticket number IGN-11528.
We're delegating the internal string -\> number type to an external library, and that external library goes from smallest -\> largest possible presentation, and `13.3` happens to be a value that can be (acceptably to the library, at least) represented in a 32-bit float, and therefore that's what is returned.
Changing that logic in the numeric text field risks regressions in the other direction - there is no winning. We talked about the idea of introducing a "precision" editor component that worked the other way, but deferred it due to relative lack of demand.
What you could do today would be to use a _formatted_ text field, with a regex to only allow numeric inputs, and 'bind' the writes back to a tag yourself.
_[View the full topic](https://forum.inductiveautomation.com/t/numeric-text-field-float-vs-double-issue/117737)._
