HI,
I use OPC factory server to link a M580 schneider PLC to ignition. I created a DDT in the PLC which is a struct of REAL values :
I created an instance of the DDT named vfd_status_501:
The instance of the DDT is perceived by ignition, but only as a tag, not as a folder of tags:
When I read the tag in OPC Quick Client, I get the following message :
But in OFS client, I see the variables of the DDT correctly:
What is the issue?
