# Opening a popup window from another popup window
**URL:** <https://forum.inductiveautomation.com/t/opening-a-popup-window-from-another-popup-window/9039>\
**Created:** [September 10, 2014, 4:16pm UTC](https://forum.inductiveautomation.com/t/opening-a-popup-window-from-another-popup-window/9039 "2014-09-10T16:16:24Z")\
**Posts on this page:** 3\
**Author:** ![SonicClang](https://avatars.discourse-cdn.com/v4/letter/s/eada6e/32.png) [@SonicClang](https://forum.inductiveautomation.com/u/SonicClang)\
**Post date:** [September 10, 2014, 4:16pm UTC](https://forum.inductiveautomation.com/t/opening-a-popup-window-from-another-popup-window/9039/1 "2014-09-10T16:16:24Z")
I’m trying to open a popup window from another popup window and it’s popping under instead of over. I can’t figure out the right set of radio buttons/check boxes to make it function the way I want.
**Post date:** [September 10, 2014, 5:46pm UTC](https://forum.inductiveautomation.com/t/opening-a-popup-window-from-another-popup-window/9039/2 "2014-09-10T17:46:12Z")
Did you set your layer for the new popup to be higher than the current one?
**Post date:** [September 10, 2014, 5:52pm UTC](https://forum.inductiveautomation.com/t/opening-a-popup-window-from-another-popup-window/9039/3 "2014-09-10T17:52:41Z")
No! Thank you!!
It’s been a number of months since I’ve worked in Ignition, and I wasn’t an expert before. I totally forgot about the layers.
