# OR Statements With Expression Tags
**URL:** <https://forum.inductiveautomation.com/t/or-statements-with-expression-tags/99352>\
**Tags:** perspective, scripting\
**Created:** [December 3, 2024, 7:40am UTC](https://forum.inductiveautomation.com/t/or-statements-with-expression-tags/99352 "2024-12-03T07:40:11Z")\
**Post date:** [December 3, 2024, 8:13am UTC](https://forum.inductiveautomation.com/t/or-statements-with-expression-tags/99352/2 "2024-12-03T08:13:26Z")
Welcome to the forum, Christopher. A couple of points:
> [@Christopher\_Cooper1](#):
> Since ignition uses jython, the "or" and "OR" expressions from python do not appear to work, so using || is a good work around.
Ignition uses Jython for **scripting**. Your
`{[~]FOLDER NAME/TAG_NAME.value} || {[~]FOLDER NAME/TAG_NAME.value}`
is an **expression** and follows the documented rules for [Expression Language and Syntax | Ignition User Manual](https://www.docs.inductiveautomation.com/docs/8.1/platform/expression-language-and-syntax) (where you will find the _logical OR_ syntax documented). You can think of Ignition's expression language as being like a spreadsheet's functions.
> Expressions often involve one or more other values that are used to calculate a final value. In most cases, expressions only return a value.
In Excel you would use VBA (Visual Basic for Applications) for scripting and in Ignition it would be Jython.
For posting code here, please see [Wiki - how to post code on this forum](https://forum.inductiveautomation.com/t/wiki-how-to-post-code-on-this-forum/77831).
_[View the full topic](https://forum.inductiveautomation.com/t/or-statements-with-expression-tags/99352)._
